Flooky Posted June 9, 2020 Report Share Posted June 9, 2020 (edited) Hi, my sons txt racings fuel tank is leaking from the spigot that the the fuel tap pushes into. I thought it was the tap but its the spout/spigot that the tap pushes into. On further inspection it is threaded into the tank with a bonding agent at the factory, the part is not available a on its own it comes as part of a new tank. I was wondering if anybody else has had this happen and what you used to seal it ? I have ordered some JB weld plastic bond which is apparently fuel resistant, but any other ideas would be very welcome. cheers. Edited June 9, 2020 by Flooky Quote Link to comment Share on other sites More sharing options...
misscrabstick Posted June 9, 2020 Report Share Posted June 9, 2020 What is the tank made of? I would be tempted to solder it if it's steel and if it's aluminium then use one of those low temp ally weld sticks and a gas torch, either way you need to flush the tank out thoroughly to remove fumes and fuel. I have had this issue loads of times with vintage gas tanks on old farm engines and repaired without issues. Quote Link to comment Share on other sites More sharing options...
huski Posted June 9, 2020 Report Share Posted June 9, 2020 Used JB weld on mine when it had the same problem.It held for the 2 years I had the bike.You have to get the area really clean,I scuffed it up then zapped it with brake cleaner Quote Link to comment Share on other sites More sharing options...
Flooky Posted June 9, 2020 Author Report Share Posted June 9, 2020 4 hours ago, misscrabstick said: What is the tank made of? I would be tempted to solder it if it's steel and if it's aluminium then use one of those low temp ally weld sticks and a gas torch, either way you need to flush the tank out thoroughly to remove fumes and fuel. I have had this issue loads of times with vintage gas tanks on old farm engines and repaired without issues. plastic tank so not really an option, but thanks Quote Link to comment Share on other sites More sharing options...
Flooky Posted June 9, 2020 Author Report Share Posted June 9, 2020 2 hours ago, huski said: Used JB weld on mine when it had the same problem.It held for the 2 years I had the bike.You have to get the area really clean,I scuffed it up then zapped it with brake cleaner cheers, what JB weld did you use ? standard or plastic bond, I have got standard but ordered jb weld plastic bond thinking it would be better. Quote Link to comment Share on other sites More sharing options...
huski Posted June 9, 2020 Report Share Posted June 9, 2020 Hi,I used the normal one,not realising there was an alternative.Id use the plastic one,can't be worse Quote Link to comment Share on other sites More sharing options...
mbeers6 Posted June 9, 2020 Report Share Posted June 9, 2020 I had same issue with mine, dealer suggested and I have used TWICE now 3M windshield adhesive (black colored). Just get the area totally clean and free from gas/oil like the prior person said. https://www.3m.com/3M/en_US/company-us/all-3m-products/~/3M-Auto-Glass-Urethane-Windshield-Adhesive/?N=5002385+3293242009&rt=rud Quote Link to comment Share on other sites More sharing options...
Flooky Posted June 9, 2020 Author Report Share Posted June 9, 2020 (edited) 3 hours ago, huski said: Hi,I used the normal one,not realising there was an alternative.Id use the plastic one,can't be worse cheers, I will. did you unscrew the fitting and jb weld the threads or just smear it around the rim with it screwed in ? Edited June 9, 2020 by Flooky Quote Link to comment Share on other sites More sharing options...
Flooky Posted June 9, 2020 Author Report Share Posted June 9, 2020 2 hours ago, mbeers6 said: I had same issue with mine, dealer suggested and I have used TWICE now 3M windshield adhesive (black colored). Just get the area totally clean and free from gas/oil like the prior person said. https://www.3m.com/3M/en_US/company-us/all-3m-products/~/3M-Auto-Glass-Urethane-Windshield-Adhesive/?N=5002385+3293242009&rt=rud great idea, I think I have got some but maybe not 3m. cheers good call Quote Link to comment Share on other sites More sharing options...
Flooky Posted June 9, 2020 Author Report Share Posted June 9, 2020 (edited) Thanks all Edited June 9, 2020 by Flooky Quote Link to comment Share on other sites More sharing options...
huski Posted June 9, 2020 Report Share Posted June 9, 2020 10 minutes ago, Flooky said: cheers, I will. did you unscrew the fitting and jb weld the threads or just smear it around the rim with it screwed in ? On mine the tap was held in with a hose clip and ju st pushed in.I removed the tap for easier access Quote Link to comment Share on other sites More sharing options...
mbeers6 Posted June 10, 2020 Report Share Posted June 10, 2020 Whatever adhesive you use, yes I would take the fitting out and clean everything. Then apply it and let it sit overnight before you add fuel. Quote Link to comment Share on other sites More sharing options...
Flooky Posted June 10, 2020 Author Report Share Posted June 10, 2020 thanks all, I will give it a go with jb weld plastic bond. and let you know how it goes Quote Link to comment Share on other sites More sharing options...
baldilocks Posted June 21, 2021 Report Share Posted June 21, 2021 On 6/10/2020 at 6:38 PM, Flooky said: thanks all, I will give it a go with jb weld plastic bond. and let you know how it goes @flooky did jb plastic weld work ? Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 21, 2021 Report Share Posted June 21, 2021 That does not sound good. Good luck on the leak. Quote Link to comment Share on other sites More sharing options...
