Mcasp Posted June 13, 2020 Report Share Posted June 13, 2020 Hi all, My son has a 2009 gas gas 125 txt pro , last time sewers out of ran fine, just changed gearbox oil,ready for tomorrow started it up ,and it has a knocking sound which when clutch lever is pulled in stops, also when put into gear stalls ( drag??) Any ideas Thanks Paul Quote Link to comment Share on other sites More sharing options...
thall1 Posted June 13, 2020 Report Share Posted June 13, 2020 That’s the clutch basket rattling... pretty normal for a gas gas. How much oil have you put in... usually about 450 ml for an oil change from what I can remember. check you have free play on the clutch lever... if you have and the clutch still doesn’t clear then I expect the master cylinder piston will need replacing Quote Link to comment Share on other sites More sharing options...
Mcasp Posted June 13, 2020 Author Report Share Posted June 13, 2020 Hi thall, 400 ml I may put another 50 in then ! Fluid a bit low in m/cyl ! Cause? Thanks Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 14, 2020 Report Share Posted June 14, 2020 There are two o rings in the clutch case that can go bad. You are using mineral oil in the clutch master cylinder. Quote Link to comment Share on other sites More sharing options...
Mcasp Posted June 14, 2020 Author Report Share Posted June 14, 2020 On the I'm gonna strip clutch and have a look .not sure which fluid not changed it since had bike!! Quote Link to comment Share on other sites More sharing options...
