Gas gas clutch knock
Mcasp
Hi all,
My son has  a 2009 gas gas 125 txt pro , last time sewers out of ran fine, just changed gearbox oil,ready for tomorrow started it up ,and it has a knocking sound which when clutch lever is pulled in stops, also when put into gear stalls ( drag??) Any ideas
Thanks Paul
That’s the clutch basket rattling... pretty normal for a gas gas. How much oil have you put in... usually about 450 ml for an oil change from what I can remember.
check you have free play on the clutch lever... if you have and the clutch still doesn’t clear then I expect the master cylinder piston will need replacing
