Brooksy Posted June 14, 2020 Report Share Posted June 14, 2020 (edited) Having bought a gas gas txt 300 2004 my first problem was a mid box and end pipe now today's problems my kickstart and spindle pull out half inch and back but today I kicked it it made a horrible grinding noise like it would if I pushed the kick down why running I immediately kicked it in the half inch and it went secondly my tank had a normal screw with a bolt on the other end you could only imagine how difficult that was to get of with zearo room I'm gonna buy the proper screw but I'm missing the bracket under the tank I'm not sure what there called as it's just a hole any info on the 2 situations would be brilliant I'm at a horrible stage we're I've bought the bike and need to spend to make it normal I am gonna lose money I no this but that's what you get being uneducated on bikes and buying from Rob dogs Edited June 14, 2020 by Brooksy Spelling 1 Quote Link to comment Share on other sites More sharing options...
tony27 Posted June 14, 2020 Report Share Posted June 14, 2020 If it's like most steel framed bikes the bolt should fit into what is called a nut clip at the back end of the tank, should be easy to get. Sounds like there is something missing in your kickstart assembly https://www.splatshop.co.uk/m6-nut-clip.html 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 14, 2020 Report Share Posted June 14, 2020 You cannot push the kicker down while running on any motorcycle. Quote Link to comment Share on other sites More sharing options...
Brooksy Posted June 14, 2020 Author Report Share Posted June 14, 2020 Lineway sorry maybe I didn't explain properly what I ment was it gave the same noise as if I did do that like the grinding noise my friend said it could be Idler gear hitting clutch basket or somthing I don't no Quote Link to comment Share on other sites More sharing options...
Brooksy Posted June 14, 2020 Author Report Share Posted June 14, 2020 (edited) 56 minutes ago, tony27 said: If it's like most steel framed bikes the bolt should fit into what is called a nut clip at the back end of the tank, should be easy to get. Sounds like there is something missing in your kickstart assembly https://www.splatshop.co.uk/m6-nut-clip.html Thankyou I have been looking every were its embarrassing but I was sat a whole 2 hours trying to figure out how to get my nut in behind the fairing on either side not knowing I had to take the top bolt out my tank to move it up I appreciate that thankyou again Edited June 14, 2020 by Brooksy Quote Link to comment Share on other sites More sharing options...
