Limmy01 Posted June 20, 2020 Report Share Posted June 20, 2020 Was out last weekend and the bike was faultless till the last hour when she decided to just stop.. Got it hope and it started but with a clicking sound and kept cutting out, then she wouldn't start and had no spark. Took it apart and whoever fitted the kill switch was bodged in.. sorted all the wires and did some soldering and the spark is back, rebuilt and she started first time for 6 seconds and now won't start again.. I have a spark also.. What do I need to check? Quote Link to comment Share on other sites More sharing options...
b40rt Posted June 20, 2020 Report Share Posted June 20, 2020 Always try another plug. Is the plug wet or dry ? Quote Link to comment Share on other sites More sharing options...
dan williams Posted June 20, 2020 Report Share Posted June 20, 2020 (edited) Betas with a trigger coil ignition are notorious for failures in the trigger circuit. The symptoms are similar to what you describe. Runs sometimes. Then won’t start. Then after a while starts but runs crappy. They usually show spark but never enough to get a timing light on it so it could be sparking anywhere in the cycle. It’s become the standard recommendation to just send the stator off to a rewinding house to have it checked and usually they will tell you it’s broken. The good news is a rewound stator is cheaper than new and in all cases I have dealt with has fixed the problem permanently. The new bikes don’t use a trigger coil. So Beta peeps, any recommendation for rewinders? Does West Country still do Beta stators? Looks like trialsport also does rewinding and they have a video of their test jig. Shed engineering at its finest. Edited June 20, 2020 by dan williams Quote Link to comment Share on other sites More sharing options...
reggie Posted June 21, 2020 Report Share Posted June 21, 2020 check the woodruff key it may be sheered Quote Link to comment Share on other sites More sharing options...
Limmy01 Posted June 21, 2020 Author Report Share Posted June 21, 2020 On 6/20/2020 at 7:14 PM, b40rt said: Always try another plug. Is the plug wet or dry ? Expand Plug was wet Quote Link to comment Share on other sites More sharing options...
Limmy01 Posted June 21, 2020 Author Report Share Posted June 21, 2020 On 6/20/2020 at 11:04 PM, dan williams said: Betas with a trigger coil ignition are notorious for failures in the trigger circuit. The symptoms are similar to what you describe. Runs sometimes. Then won’t start. Then after a while starts but runs crappy. They usually show spark but never enough to get a timing light on it so it could be sparking anywhere in the cycle. It’s become the standard recommendation to just send the stator off to a rewinding house to have it checked and usually they will tell you it’s broken. The good news is a rewound stator is cheaper than new and in all cases I have dealt with has fixed the problem permanently. The new bikes don’t use a trigger coil. So Beta peeps, any recommendation for rewinders? Does West Country still do Beta stators? Looks like trialsport also does rewinding and they have a video of their test jig. Shed engineering at its finest. Expand Update, After drying the plug and heating it up over the cooker, she started faultless.. so now the conundrum is do i carry on and see if it stops again and then get the stator done, or do I do that now and not risk it... Quote Link to comment Share on other sites More sharing options...
jonboy883 Posted June 21, 2020 Report Share Posted June 21, 2020 (edited) Use it until it happens again, and while your using it, your back up is to research where to send it! Edited June 21, 2020 by jonboy883 2 Quote Link to comment Share on other sites More sharing options...
b40rt Posted June 21, 2020 Report Share Posted June 21, 2020 On 6/21/2020 at 6:32 AM, Limmy01 said: Update, After drying the plug and heating it up over the cooker, she started faultless.. so now the conundrum is do i carry on and see if it stops again and then get the stator done, or do I do that now and not risk it... Expand Hopefully it was just flooded, was the petrol left on ? If it happens again I'd get it rewound. Quote Link to comment Share on other sites More sharing options...
dan williams Posted June 22, 2020 Report Share Posted June 22, 2020 Someone just posted on FB a comment on having a cracked spark plug cap. Good reminder. I’ve also seen it necessary to cut about ten mm of the spark cable and reattach the spark cap. Quote Link to comment Share on other sites More sharing options...
