Jgas oil filter
  • 4 months later...
In fact the Jotagas have an oil filter but not in the common way ( your car ) ,the oil filter is for the clutch and the gearbox, very easy and important to clean it ! Take off the clutch cover , take off the 10 Hex bolts and the steel ring ,who is also the diafram spring, will show you the filtered materials! Clean it and reassemble everything and you ´re done !!
