jgasjoel2014 Posted June 27, 2020 Report Share Posted June 27, 2020 Jotagas 2014....Clutch master cylinder (red top) seems to be leaking fluid from the shroud next to it, its not sat over the spring right and won't stay when corrected.... then when I started riding it the bike wanted to set off while clutch still pulled in.. what is it guys?? Quote Link to comment Share on other sites More sharing options...
lowbrow Posted June 28, 2020 Report Share Posted June 28, 2020 Master cylinder seals are leaking. Remove the circlip to extract the piston. The master cylinder bore could be damaged or worn, but more often than not new seals will cure the problem. 1 Quote Link to comment Share on other sites More sharing options...
