betaridder Posted June 30, 2020 Report Share Posted June 30, 2020 Hi everyone I have a shift moped of the brand beta but if I have driven for a while I can still shift gears perfectly but neutral succeeds that not so well when I turn off my moped it succeeds back perfectly you may know why or you tips ps I have already replaced motor oil thanks in advance Quote Link to comment Share on other sites More sharing options...
wobblenorbed Posted June 30, 2020 Report Share Posted June 30, 2020 Hi there. This is normal in my experience. Quote Link to comment Share on other sites More sharing options...
betaridder Posted June 30, 2020 Author Report Share Posted June 30, 2020 Hey so I really can't do anything about it or change it so that it is good because with friends of mine, they have no last Quote Link to comment Share on other sites More sharing options...
wobblenorbed Posted June 30, 2020 Report Share Posted June 30, 2020 I personally use my hand when I want neutral when I come to a stop. I can easily get neutral when the bike is still rolling. Quote Link to comment Share on other sites More sharing options...
betaridder Posted June 30, 2020 Author Report Share Posted June 30, 2020 3 minutes ago, wobblenorbed said: I personally use my hand when I want neutral when I come to a stop. I can easily get neutral when the bike is still rolling. I cannot go into neutral at all when my moped is still running but if I have turned it off then it is perfect Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted June 30, 2020 Report Share Posted June 30, 2020 3 hours ago, betaridder said: Hey so I really can't do anything about it or change it so that it is good because with friends of mine, they have no last A bit of gentle and patient prodding with your foot will get neutral eventually. Using a last would be far too violent. 1 1 Quote Link to comment Share on other sites More sharing options...
viking Posted August 14, 2020 Report Share Posted August 14, 2020 Hello! Try the "Beta Clutch Fix" ! Perhaps you have clutch drag and thats why you have problems to get it in the neutral when the motor is running. Quote Link to comment Share on other sites More sharing options...
dan williams Posted August 14, 2020 Report Share Posted August 14, 2020 Neutral is always difficult because the neutral notch on the cam is smaller and in between two larger notches. As pointed out clutch drag doesn’t help either. I find getting neutral from first almost impossible. From second just a light tap on the lever usually gets it but it’s not a sure thing. Quote Link to comment Share on other sites More sharing options...
pindie Posted August 15, 2020 Report Share Posted August 15, 2020 Try a quick blip of throttle as you try for neutral as well. It often helps. Make sure the clutch fluid is fresh and well bled. Putoline Nanotrans GP gearbox oil can help with clutch drag issues. Quote Link to comment Share on other sites More sharing options...
dan williams Posted August 17, 2020 Report Share Posted August 17, 2020 On 8/15/2020 at 1:23 AM, pindie said: Try a quick blip of throttle as you try for neutral as well. It often helps. One of those things a lot of people do but not on a conscious level. Quote Link to comment Share on other sites More sharing options...
