Paint suggestions for caliper
faussy
Wanting to paint my front ajp caliper black to make it look like an original grimeca. Given that i always spill brake fluid when bleeding should i worry about the type of paint i use? Rattle can do ok, or should i use 2k? Im thinking high temp matt black may give the most realistic satin look, but worried it will just rub off when i spill brake fluid over it
Edited by faussy
2K would be better than a can, but you may get good results with a can on something as small as a caliper
High temp paint may be needed on a road bike, but would a trials brake get hot enough to need it ?
as for brake fluid , I think some of the modern fluids are glycol based , which is not so  harmful to paintwork as the older fluids were
Expand
I wouldn't say they get hot often but I have seen them get very hot when doing a long loop or a trial with a lot of hills so it defiantly can happen.
  • 5 months later...
