cde050583 Posted July 7, 2020 Report Share Posted July 7, 2020 Hi all, new to the forum and hoping someone can help. Could anyone tell me where to locate a piston for my 221 frame number sherpa t 125. The piston measures 60mm and as far as I can tell from the lack of markings it's a standard size. The bore measures 60.986mm. I have looked at the usual sites, french classics, in motion etc but can not find a listing. Even good old flea bay had not come up with the goods. Any help greatly appreciated. Quote Link to comment Share on other sites More sharing options...
johnjsy Posted July 7, 2020 Report Share Posted July 7, 2020 Hi, Kevin Brendon Racing is a good place to have a look. Although his Bultaco listings start at 250, there may be a close match for a different. The Montesa ones start at 61mm, well worth a look. When you get fixed up, post again on here, the info could help others. Quote Link to comment Share on other sites More sharing options...
naichuff Posted July 7, 2020 Report Share Posted July 7, 2020 My sherpa t is a 221 but is a 175 ?Had it since new but never had the head off but done a lot of work So are they 125 or 175 !! Quote Link to comment Share on other sites More sharing options...
woody Posted July 7, 2020 Report Share Posted July 7, 2020 On 7/7/2020 at 5:32 PM, cde050583 said: Hi all, new to the forum and hoping someone can help. Could anyone tell me where to locate a piston for my 221 frame number sherpa t 125. The piston measures 60mm and as far as I can tell from the lack of markings it's a standard size. The bore measures 60.986mm. I have looked at the usual sites, french classics, in motion etc but can not find a listing. Even good old flea bay had not come up with the goods. Any help greatly appreciated. Expand Your bike, a model 221, is a 175cc. The Sherpa 125cc is a model 185 and has a bore of 54mm The model 221 uses a 250cc engine which is sleeved down to 175cc so you can use a 250 piston and bore it back to 250 if you can't find the 61mm oversize piston 3 Quote Link to comment Share on other sites More sharing options...
