Beta 80 Senior Forks
baldilocks
Thanks guys. Wire coil is 4.7mm thick. These forks only have the spring in one side so ive found some springs on line from an earlier set of 38mm which had a spring in both sides so I'll try one of them,  length is within adjustment range on the fork and wire coil is 4mm
My son only weighs 37kg but these forks are firmer than the tech forks in my TRS
  • 1 year later...
Expand
Did the softer spring work Baldilocks ? If so can you give details or link to spring you found please ? I’m trying to soften forks for my son. Thanks.
