Chillipig Posted July 26, 2020 Report Share Posted July 26, 2020 Hello, my name is Wayne I ride a Gas Gas JT250 1995. My electric fan has stopped working and was wondering if any one knew where to get a replacement? I've tried Ebay and other online shops but drawing a blank at the moment. Any help would be much appreciated. Many Thanks Wayne. Quote Link to comment Share on other sites More sharing options...
Bilko Posted July 26, 2020 Report Share Posted July 26, 2020 Have you tried the fan connected to a 12v battery it might be your stats thats packed up. Quote Link to comment Share on other sites More sharing options...
Chillipig Posted July 27, 2020 Author Report Share Posted July 27, 2020 What a good idea. I will try that first. Thank you. Quote Link to comment Share on other sites More sharing options...
Chillipig Posted July 28, 2020 Author Report Share Posted July 28, 2020 By way of an update: Before I had chance to check the fan using a battery I noticed that I had the two wires going into the thermostat the wrong way round. Swapped them, took the bike for a good run to get up to operating temperature and the fan worked. Mystery solved but thank you for the advice. Quote Link to comment Share on other sites More sharing options...
section swept Posted July 28, 2020 Report Share Posted July 28, 2020 Well spotted Chillipig. Might be a good idea to use your eagle eyes to thoroughly check the rest of the bike over for ‘other’ faults/issues. Quote Link to comment Share on other sites More sharing options...
Chillipig Posted July 29, 2020 Author Report Share Posted July 29, 2020 Thank you. That got me thinking. I recently changed the small end bearing and its likely that I've over looked something else as part of the tear down and rebuild, wires to the thermostat case in point. I'll spend some time this weekend double checking. Quote Link to comment Share on other sites More sharing options...
