Ben65 Posted August 17, 2020 Report Share Posted August 17, 2020 Hi guys- I’m new to this site, and Sherco. ive bought what the VIN tells me is a 2013 Factory 300, but with all the research I’ve done, I’m yet to find another like it. ive heard that Sherco has mucked up VINs in the past( this may be completely untrue??). My Bike has a white frame, Blue(Factory logo’d) rims, Ohlins shock, Black forks with red adjusters on top, Cabestany logo’d air box cover, triple clamps with Limited Edition 147 engraved on them. It also has a map switch LHS near radiator and black ‘bars. Does this sound like a 2013?? It was sold to me as a 2015. It rides fantastically so far- quite a bit different to my old Gasser TXT PRO 2004 250( thankfully!!) Im also chasing a manual for it, but can’t find any. The guy I bought it off said to run at 80:1 on 95RON- sound ok? thanks guys- any helpful info would be greatly appreciated. Ben Quote Link to comment Share on other sites More sharing options...
faussy Posted August 17, 2020 Report Share Posted August 17, 2020 (edited) Can you put pic up? White frame is pointing to 2013, but they never had black forks or blue rims that far back, only gold Edited August 17, 2020 by faussy Quote Link to comment Share on other sites More sharing options...
Ben65 Posted August 17, 2020 Author Report Share Posted August 17, 2020 Quote Link to comment Share on other sites More sharing options...
Ben65 Posted August 17, 2020 Author Report Share Posted August 17, 2020 If it is a 2013, were there any complaints about this model, or anything that should be checked? Quote Link to comment Share on other sites More sharing options...
faussy Posted August 17, 2020 Report Share Posted August 17, 2020 (edited) Looks like a 2015 factory, but with a custom white painted frame... Gold triple clamps, gold head, forks and wheels are all 2015 Ill let the sherco experts answer the rest, but afaik the only real problems was with the carb diaphragm pump and some didn't run great, but i think this was more contained to the early models of the reverse tank and airbox, around 2011. If it runs ok then i guess its ok 80:1 i guess is fine if you aren't overly hard on it. If you like a lot of throttle or trail riding, id maybe try closer to 60 or 70:1. Personally i like to errr on the side of more oil, but everyone has their preference https://www.sherco.com/wp-content/uploads/manual_2015_ST.pdf Edited August 17, 2020 by faussy Quote Link to comment Share on other sites More sharing options...
cascao Posted August 18, 2020 Report Share Posted August 18, 2020 Noted formula clutch master. From 2013. But brake caliper seems braktec/Ajp Quote Link to comment Share on other sites More sharing options...
Ben65 Posted August 18, 2020 Author Report Share Posted August 18, 2020 2 hours ago, cascao said: Noted formula clutch master. From 2013. But brake caliper seems braktec/Ajp Is this good? Maybe it’s just had later rims put on it?? Are the forks etc from 2013? Quote Link to comment Share on other sites More sharing options...
cascao Posted August 19, 2020 Report Share Posted August 19, 2020 In 2013 we didn't had black forks yet. Formula brakes aren't good. But could see only clutch master. Quote Link to comment Share on other sites More sharing options...
