MOSSA Posted September 24, 2020 Author Report Share Posted September 24, 2020 On 9/23/2020 at 11:26 PM, lotus54 said: To adjust properly, you need the software/hardware. Check to see that the throttle plate is closing all the way- and no air leaks. Checking with software to see ignition timing may be good too? Expand Thanks. I backed out the cable throttle stop screw on the outside of the intake and that did it. Not sure why it changed. Quote Link to comment Share on other sites More sharing options...
