TR280i running issues
MOSSA
1 hour ago, lotus54 said:
 To adjust properly, you need the software/hardware.
   Check to see that the throttle plate is closing all the way- and no air leaks.   Checking with software to see ignition timing may be good too?
Thanks. I backed out the cable throttle stop screw on the outside of the intake and that did it. Not sure why it changed.
