hgas Posted August 26, 2020 Report Share Posted August 26, 2020 Hi every one I know this has been covered a few times but I haven’t been able to find a step by step guide on how to actually remove the additional weight that’s pressed onto the gear on an evo ?I’m going to remove the flywheel weight aswell (Covid boredom+intrigue) I believe that a puller is needed for the gear side aswell to remove it ? Any tips or tricks would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
dan williams Posted August 27, 2020 Report Share Posted August 27, 2020 Try removing the flywheel weight first to see if you like it with less flywheel. Easier to do one step at a time. 1 Quote Link to comment Share on other sites More sharing options...
peterb Posted August 28, 2020 Report Share Posted August 28, 2020 If the Evo motor is the same as the Rev 3, then the LHS weight is on a tapered shaft so you will need to fabricate a puller for that, I have the hole centres for the Rev 3 if you'd like this info. Bye, Peter B. Quote Link to comment Share on other sites More sharing options...
