Joe10 Posted August 31, 2020 Report Share Posted August 31, 2020 I bought a new 2020 txt 250 and after riding it for about 3 to 4 hours the clutch stopped working. I noticed it was low on fluid and added mineral oil and it started working again. After about another hour of riding I checked it and noticed it had leaked down some again. Being its almost new has anyone ran into this issue? Thanks for any suggestions. The dealer I bought if from is 7 hours away so if its something small I may try to fix it myself. Also it doesn't seam to be leaking at clutch lever. Quote Link to comment Share on other sites More sharing options...
vectradam Posted August 31, 2020 Report Share Posted August 31, 2020 Hi My nearly new TRS did exactly the same and it turned out to be the banjo fitting was leaking where the pipe goes into the Gearbox casing. New Dowty seal cured it.It was very difficult to see with mud and water etc about. Quote Link to comment Share on other sites More sharing options...
Joe10 Posted August 31, 2020 Author Report Share Posted August 31, 2020 Thanks for the input, I will check into that. Quote Link to comment Share on other sites More sharing options...
feetupsbetter Posted August 31, 2020 Report Share Posted August 31, 2020 I had similar on a gasser some years ago. Dropped it in a rocky stream section, picked it up & restarted but no clutch. On closer inspection there was a small impact mark on the casing just where the boss is tapped for the banjo bolt. Turns out it must have fallen on a rock just at that point, and it cracked the casing but on the inside of the tapping ( maybe the impact was on the banjo itself ). Nothing much to see on the outside unless you pumped the lever half a dozen times in quick succession and then you’d see a slight leakage. Obviously mine needed a new case, hope yours is just the washer ! Quote Link to comment Share on other sites More sharing options...
Joe10 Posted August 31, 2020 Author Report Share Posted August 31, 2020 Ok, thanks for input Quote Link to comment Share on other sites More sharing options...
lineaway Posted September 1, 2020 Report Share Posted September 1, 2020 New Gassers clutch losing fluid with no visual leaks would be the orings in the slave cylinder. Quote Link to comment Share on other sites More sharing options...
Joe10 Posted September 1, 2020 Author Report Share Posted September 1, 2020 Thanks Quote Link to comment Share on other sites More sharing options...
