Gas gas txt 1999
Teddydanson
Hi guys.
been out for about 30-40 mins in the bike, 1st outing since lock down. Was flying fine everywhere, then all of a sudden was squealing as if something was stuck, stopped the bike put it 1st gear and still squealing, sounded like the head. But not sure, now I had to start it again to get up a massive hill... still doing it, I popped it into 2nd and it stopped, then third still ok, ran it all the way home and it was fine... washed it and tried to start it again, it keeps select gear on its own with the slightest knock or roll, then really hard to select neutral..
I’m running it on 75-80 /1 fuel
and changed the gearbox oil. Light gear oil 75w putiline
theres obviously  something wrong?
how do I check clutch, or could it be piston...
I’m  lost, but don’t fancy paying hundreds to sit in a shop.. any help would be great guys
Edited by Teddydanson
Decided to look at the clutch? Seemed ok, put everything back togeather, then pressed the lever, nothing then all of a sudden got stiff, I looked down to the left of the bike, and the clutch cylinder above the small chain sprocket was moving, then all of a sudden if spewed oil out.. loads of it... I’ve put it away now as am not feeling the vibe and can’t bare to look at it as I’m assuming this is serious...
something has gone, and when I lean it over it p****s oil out on the left hand side...
