phiggs Posted November 18, 2020 Report Share Posted November 18, 2020 (edited) The rubber O ring on the base of the needle jet is the most important part of that expensive kit. The float bowl should be a tight push fit onto it, and should not just fall off. Unfortunately the O ring is not a standard size, but something like 4.6 x 2.0 mm ( If you have a kit of O Rings from Halfords, it will not have this unique size.) . Edited March 2, 2021 by phiggs 1 Quote Link to comment Share on other sites More sharing options...
