madproffesor Posted February 2, 2006 Report Share Posted February 2, 2006 I am restoring a pre pinky TY 250 with a group of school kids in Thailand and I am having problems with the front wheel spindle. Is there a specific tool or does anyone know of a suitable alternative. Obviously getting genuine tools is an issue out here. Any general help would be appriciated. Quote Link to comment Share on other sites More sharing options...
yamaha_rocks Posted February 2, 2006 Report Share Posted February 2, 2006 I used a hex head bolt with vice grips until i bought a 12mm allen key socket, that is assuming the spindle is the same as a pinky . Quote Link to comment Share on other sites More sharing options...
madproffesor Posted February 2, 2006 Author Report Share Posted February 2, 2006 Thanks for that. Mine seems to have a twelve sided torque insert. Did you fit the allen key into that? I tried the bolt head trick but it did not even touch it. I have released the single lock bolt on the other side. Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted February 2, 2006 Report Share Posted February 2, 2006 Never seen anything like 12 point on a TY. Try some penetrating oil and mild heat on the nut side. The 2 metals may have reacted. Use anti-seize on the thread and grease the spindle when you put it back together. Quote Link to comment Share on other sites More sharing options...
arun1664 Posted February 2, 2006 Report Share Posted February 2, 2006 I think my Pinkie had the 12 pointed star you talk about. If I recall I used a 3/4 inch ratchet drive. Failing that a square profile will fit into a 12 face internal so maybe get hold of a bit of stock steel rod, alternativly time to introduce the kids to the art of filing ! Quote Link to comment Share on other sites More sharing options...
martinm Posted February 2, 2006 Report Share Posted February 2, 2006 Try this.... Disconnect the front brake cable, tighten the clamp back up on the spindle, take off the front mudguard and brace, loosen all of the pinch bolts in the yokes, slide out the wheel and forks as a complete unit.........then grab hold of the top of the forks and use them as a lever to undo the spindle. Good luck Martin Quote Link to comment Share on other sites More sharing options...
madproffesor Posted February 4, 2006 Author Report Share Posted February 4, 2006 Fantastic taking the front off worked a treat, would off helped if the previous owner hadnt put loctite on the spindle though. Kids think you are a god as they are a little closer to riding it now. Quote Link to comment Share on other sites More sharing options...
hughesy Posted February 4, 2006 Report Share Posted February 4, 2006 If you want an original Yam spanner which incorporates an allen key then PM me with your address and I'll send one FOC as I've got loads. The spindle is basically a Bi-Hex allen bolt by the way. Quote Link to comment Share on other sites More sharing options...
kevin j Posted February 5, 2006 Report Share Posted February 5, 2006 My TY350 fits a 'Torx' driver. I don't recall the size, they are named as T10, T15 etc. Try your local industrial supplier as Torx screws are common now. I have a socket to fit a normal 3/8 drive handle. kcj Quote Link to comment Share on other sites More sharing options...
