chudder Posted October 10, 2020 Report Share Posted October 10, 2020 my recently bought 348 was missing the front brake torque arm.No problem I thought, 2 on ebay both saying for 348 both 5155.050 .Got one and it does not fit! seems to be too long. Whats happened.Could be getting the grinder and welder out. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted October 10, 2020 Report Share Posted October 10, 2020 Post up a photo if you want to know what's up Quote Link to comment Share on other sites More sharing options...
fourex Posted October 10, 2020 Report Share Posted October 10, 2020 (edited) As per feetupfun, give us a pic if you can, or at least the dimensions. Cyclesavant in the US has a couple, stating 23.5cm end to end, I'm guessing 22cm hole to hole. https://www.ebay.com/itm/Montesa-NOS-51M-Cota-348-349-Alloy-Brake-Stay-p-n-5150-050-51-50-050-1/301583685771?epid=716924065&hash=item4637c9d88b:g:nvgAAOSwNSxVHvvP Edited October 10, 2020 by fourex link didn't work at first. Quote Link to comment Share on other sites More sharing options...
chudder Posted October 10, 2020 Author Report Share Posted October 10, 2020 hi,thanks for the replys.that one on ebay is the same one as i had from Motoclassic in uk. if i hold it up to the forks and line the holes up the brake pivot is in the way.If it was a bit shorter I think it would work.I could do with knowing what the hole to hole gap should be. the part number is 7355.48 on one manual Ive discovered Quote Link to comment Share on other sites More sharing options...
feetupfun Posted October 10, 2020 Report Share Posted October 10, 2020 There is normally only a tiny clearance between the torque link and the pivot arm Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted October 10, 2020 Report Share Posted October 10, 2020 (edited) I just make mine from alloy strip from the local hardware store. You can easily make one up and make the hole at the top end extended so the arm will effectively lengthen or shorten so more adjustment can be had as the brake shoes wear. Edited October 10, 2020 by cleanorbust 2 Quote Link to comment Share on other sites More sharing options...
fourex Posted October 11, 2020 Report Share Posted October 11, 2020 On 10/10/2020 at 10:17 AM, chudder said: hi,thanks for the replys.that one on ebay is the same one as i had from Motoclassic in uk. if i hold it up to the forks and line the holes up the brake pivot is in the way.If it was a bit shorter I think it would work.I could do with knowing what the hole to hole gap should be. the part number is 7355.48 on one manual Ive discovered Expand Part numbers starting with '73' are Cappra VR/VB I'm led to believe. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted October 11, 2020 Report Share Posted October 11, 2020 On 10/10/2020 at 10:17 AM, chudder said: I could do with knowing what the hole to hole gap should be. Expand My 348 is 195 mm centres Quote Link to comment Share on other sites More sharing options...
chudder Posted October 11, 2020 Author Report Share Posted October 11, 2020 Thanks everyone,195ml sounds right Quote Link to comment Share on other sites More sharing options...
