Electrical Wiring - In General
dr nosh
Now reaching the final stages of a loooong restoration of a 248.
I want to make up a simple wiring loom in order to get a 'no lights' MOT.
So this question is not specifically about the 248, but a wiring question in general.
So I have:
Black going to coil,
Green going to horn via a button on the L/H handlebar.
Red going to condenser (now mounted up and under the tank).
This is the question:
I have a button on the R/H handlebar that I want to wire as a kill button.
I just cannot get my head around how and what to wire this into? (I know I need to divert the power to the points to earth, but how)
Any help gratefully received.
Probably quite simple when I see it. Just seem to have a 'mental' blockage at the moment.
Edited by dr nosh
Tap it into the low tension (black) lead going to the coil.  Th button earths to frame killing the power going to the coil.  I don’t think your red lead should go to condensor as the condenser also is part of the coil circuit ie:black wire.  Red lead is/was probably lighting circuit
