Niall Posted October 12, 2020 Report Share Posted October 12, 2020 Lads I need help. I have a gas gas dirt bike with a Phbl 26bs carbarator in my bike and my bike has been left sitting for 2 years and I tried to start it and I wouldn’t I cleaned the carbarator and changed the gas and changed a few small pieces and now the bike starts with only choke and if won’t idle without the choke on and sometimes when I give it gas it just cuts out and also it’s blowing a lot of smoke help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
lineaway Posted October 12, 2020 Report Share Posted October 12, 2020 You need a diagram of the carb with all the pieces. Take it back apart and see if everything is there. I bet you dropped the needle jet. Quote Link to comment Share on other sites More sharing options...
Niall Posted October 14, 2020 Author Report Share Posted October 14, 2020 (edited) I did just that and I didn’t realize that the main jet is in the float bowl nut and I lost the floar bowl nut and ordered a new one and put the new one in not knowing that the main jet is screwed into it so the whole time I have been missing the main jet I have ordered one size 118 is that an okay size and also could I have done any damage by running it without the main jet Edited October 15, 2020 by Niall Quote Link to comment Share on other sites More sharing options...
lineaway Posted October 14, 2020 Report Share Posted October 14, 2020 I have no idea what bike you have. The jet depends on the bike. Running witjout the main should not have harmed it. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted October 15, 2020 Report Share Posted October 15, 2020 13 hours ago, Niall said: But is ment to be nut * theres a button to edit posts Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted October 15, 2020 Report Share Posted October 15, 2020 118 is close. you need someone who knows about carbs to set it up for you, really you do. Quote Link to comment Share on other sites More sharing options...
