Steve1984 Posted October 13, 2020 Report Share Posted October 13, 2020 Just had a 250 st dropped off this morning, hadn't done my research on them before I bought it tbh. One thing I noticed it's had the original carb swapped for kehinn, any reason? Are they better? Also where is the fuel tap on one of these? I read a topic about someone removing their carb and the fuel just poured out.. Or do they not have a tap?? Seems odd. Quote Link to comment Share on other sites More sharing options...
lineaway Posted October 13, 2020 Report Share Posted October 13, 2020 They run a vacuum fuel pump. Take off the rear fender for a good look. Quote Link to comment Share on other sites More sharing options...
Steve1984 Posted October 13, 2020 Author Report Share Posted October 13, 2020 So no more worrying about having to run the carb out after use? Is the kehinn carb a good upgrade for a 2 stroke? Quote Link to comment Share on other sites More sharing options...
cascao Posted October 14, 2020 Report Share Posted October 14, 2020 5 hours ago, Steve1984 said: Is the kehinn carb a good upgrade for a 2 stroke? Yes. Keihin is a good upgrade. Quote Link to comment Share on other sites More sharing options...
Steve1984 Posted October 14, 2020 Author Report Share Posted October 14, 2020 Thanks, I can't find much info on oil ratios for it. My beta used to be 70ml to 5L petrol. And it only lists 10/40 oil, so assuming the same as I put in my car? Quote Link to comment Share on other sites More sharing options...
faussy Posted October 14, 2020 Report Share Posted October 14, 2020 Only 2 stroke premix oil, definitely not car engine oil. The 10/40 may have been referring to the gearbox Quote Link to comment Share on other sites More sharing options...
Steve1984 Posted October 14, 2020 Author Report Share Posted October 14, 2020 The sherco manuals are pretty useless and can't find much on Google, what 2 stroke would it need? Synthetic or semi? And what type of coolant do they use? Quote Link to comment Share on other sites More sharing options...
