JonnyWobbles Posted October 14, 2020 Report Share Posted October 14, 2020 Continuing the Sherpa 198a strip down last night highlighted a couple more things! Both of the 19mm bolts securing the rear (cast) engine mount bracket were tight (didn't check torque), but there was some play allowing the engine to move slightly i.e. being cast the bracket wasn't a tight fit to the engine mounting lugs. I didn't want to tightened further due to risk of fracturing the bracket. Is this play normal or possible due to wear? Exhaust. Both silences are dirty, rusty and oily but externally fundamentally sound. Theres no indication (ie. welding) that they've ever been opened up and repacked, so can only assume they are as original and so will probably be pretty gunged up. I've had a look through the past posts and repacking seems to be the advice, but how do you do this? Unfortunately, I don't have a welder so if I opened them up to change wadding, has anyone tried riveting a sheet metal cover on the 'unseen' side etc. Cheers thanks for help! Quote Link to comment Share on other sites More sharing options...
lorenzo Posted October 14, 2020 Report Share Posted October 14, 2020 7 hours ago, JonnyWobbles said: Both of the 19mm bolts securing the rear (cast) engine mount bracket were tight (didn't check torque), but there was some play allowing the engine to move slightly i.e. being cast the bracket wasn't a tight fit to the engine mounting lugs. You can junk the cast bracket and replace with a fabricated steel one, as Bultaco themselves did on later bikes. Bracket should be obtainable new from Inmotion, or possibly secondhand on fleabay, etc. Also check carefully the (cyl.)head steady and fixings. Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted October 15, 2020 Report Share Posted October 15, 2020 The fabricated steel one is better and I would suggest buying off 'inmotion' because there are a couple of different ones and even the early 250 sherpa ones are different as the engine is mounted slightly further rearwards. Cheers Greg 1 Quote Link to comment Share on other sites More sharing options...
JonnyWobbles Posted October 15, 2020 Author Report Share Posted October 15, 2020 Thanks Lorenzo & sherpa325, I'll add one to the growing list of new bits required! Quote Link to comment Share on other sites More sharing options...
