vectradam Posted October 15, 2020 Report Share Posted October 15, 2020 Hi a few questions 1 - i am trying my freshen up my 2018 280rr. i am thinking of getting the frame powder coated and fitting some new decals. Would a set of 2020 decals fit (ie, is the frame the same for a 2018 and a 2020). 2 - has anyone used Amped decals as they are less than half the price of TRS ones. 3 - i have fitted the low compression head insert but didn't notice much difference, can i also fit a thicker head gasket or is it one or the other 4 - i want to change fork oil. I am 100kgs and already have the heaviest spring. Any suggestions on what grade fork oil to use and how much. many thanks for your help Quote Link to comment Share on other sites More sharing options...
baldilocks Posted October 17, 2020 Report Share Posted October 17, 2020 3.There's no head gasket they have o rings. You could fit an extra base gasket, this does affect port timing but still works and is common mod on lots of bikes to soften the power. Frame I think is the same but you could check with trs UK? Amped decals I've used before on a gas gas, no problems. If its an rr then you can adjust the damping, both compression and rebound, have you done this ? If not use the adjustment and stay on std oil. ? Quote Link to comment Share on other sites More sharing options...
