Tubeless rim supplier ?
andyjohnson_10850
  • 2 months later...
  • 4 weeks later...
The Morad 36 holes currently made  does not have the correct perimetral dimensions, mine was installed by a professional and had to be replaced by a second hand rim from old manufacturing.
The dimensional difference is only of 7 mm. of the total weel perimeter, enough to loose air when in use, doing an inmersion test was not detectable, so the problem was not easy to find.
The installation of tubeless rims on our bikes can not be successful if not done by a professional that knows how to correct the misalignment of the spokes, our brake diameter cubes differ from the ones the rim was designed, making recutting for proper alignment needed, not a job easy tot do.
Regards
Antonio
