Bosi rear mudguard
totty79
Does anyone know how to get a nice join between the cut off old mudguard and the bosi part? Or does everyone just duct tape over it as I've just done?
I've got the cut aligning really well apart from a small missing piece from earlier damage, but the center point of the old part sticks up around 5 or 6 mm and the whole rear edge is lose and easily lifted should anything snag on it.
It is nice and flexible though, it should cause less issues than a patched up mudguard, once damaged around the rear fixings every little knock seems to be a problem regardless of the technique used to patch them up.
Edited by totty79
Just updating in case anyone later finds this on a search.
Reducing the thickness of the last cm of the cut off mudguard by about half leaves the join still loose but it at least gives a fairly flat join when taped over.
It would have been better if it slotted under the edge of the bosi part instead of sitting on a lip.
