Sugg Posted October 24, 2020 Report Share Posted October 24, 2020 hi new to this group just trying to get my bike back up and running was out last weekend and bike started to blow white smoke out the exhaust now wont start at all just get a pop after every couple of kicks cleaned carb seems fine spark plug was abit black but still got spark but gonna replace it soon as anything else i should check ? any help would be much appriciated thanks Quote Link to comment Share on other sites More sharing options...
d2w Posted October 24, 2020 Report Share Posted October 24, 2020 (edited) I believe it's possible that the white "smoke" could in fact be steam, and this results when coolant gets by the head o-rings and enters the combustion chamber. Is your coolant level down? Pop the head and have a look around. Or remove the header pipe and view the top of the piston via the exhaust port. Edited October 24, 2020 by d2w 2 1 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted October 25, 2020 Report Share Posted October 25, 2020 Could also be a leaking crank seal on the primary drive side of the crankshaft. The test for this is if the gearbox oil is disappearing. 1 Quote Link to comment Share on other sites More sharing options...
jonboy883 Posted October 25, 2020 Report Share Posted October 25, 2020 White smoke, burning water - blue smoke, burning oil - black smoke, unburnt hydro carbons. either a head gasket, water pump seal. Check your coolant levels. Gassers I think have a history of water pump seals going. 2 1 Quote Link to comment Share on other sites More sharing options...
Sugg Posted October 25, 2020 Author Report Share Posted October 25, 2020 Thanks for all the help gonna go have a look see if I can find the problem hopefully get solved Quote Link to comment Share on other sites More sharing options...
d2w Posted October 25, 2020 Report Share Posted October 25, 2020 Further to jonboy883's post, if the water pump seal is compromised then the crankcase oil will be white/milky (in addition to the coolant level being down). If you replace the seal then you should also replace the pump shaft as the seal rides on the pump shaft and wears it. 1 Quote Link to comment Share on other sites More sharing options...
Sugg Posted October 25, 2020 Author Report Share Posted October 25, 2020 Was hoping to get this looked at today but been so busy if I need parts where is the best place Ebay ? Quote Link to comment Share on other sites More sharing options...
jonboy883 Posted October 26, 2020 Report Share Posted October 26, 2020 (edited) If it's gas gas, no go direct to John Shirts Motorcycles, the old Gasser importer prior to KTM owning them, and he will stock the item, can give tech advice and help with anything else. eBay, you only get a part ! Edited October 26, 2020 by jonboy883 1 Quote Link to comment Share on other sites More sharing options...
