detective 21 Posted October 29, 2020 Report Share Posted October 29, 2020 just got hold of a honda tl125, but it does not run well, starts up without choke, but ticks over nicely from cold and revs well enough, but then once warm is all goes wrong, the idle revs increase when blipping the throttle, it starts to bog down and does not like being under load and then is hard to start, the plug is not sooty, initially i thought condenser so i have replaced this and the coil but its still does it, the points seem in good order and timing seems right. any help appreciated Quote Link to comment Share on other sites More sharing options...
keychange Posted October 29, 2020 Report Share Posted October 29, 2020 Air leak in carbie area ...google check carbie air leak...very simple test Quote Link to comment Share on other sites More sharing options...
detective 21 Posted November 2, 2020 Author Report Share Posted November 2, 2020 i did check for an air leak but nothing was obviously changing the engine speed when checked Quote Link to comment Share on other sites More sharing options...
