Vertematidog Posted November 4, 2020 Report Share Posted November 4, 2020 (edited) Just purchased the above bike in bits. Can someone tell me where the ignition coil and the ignition unit should be mounted ? Also whats the switch thats mounted to the front number plate for, it has a rocker switch with the sign of a shower on it ? Edited November 4, 2020 by Vertematidog Year added Quote Link to comment Share on other sites More sharing options...
slack Posted November 4, 2020 Report Share Posted November 4, 2020 Hi if you remove fuel tank the coil and cdi box are next to the radiator filler spout. As for the switch it's a mapping switch to change ignition settings ... wet/dry.. Quote Link to comment Share on other sites More sharing options...
Vertematidog Posted November 4, 2020 Author Report Share Posted November 4, 2020 Thank you Slack. The tanks not on it came in boxes ! Do you know how the cdi mounts at all ? Quote Link to comment Share on other sites More sharing options...
d2w Posted November 5, 2020 Report Share Posted November 5, 2020 (edited) On my 2008s, the (Kokusan) CDI mounts under a wire tab on the left side of the frame near the steering stem.The coil mounts via a bolt into a threaded insert on the right side of the frame near the steering stem (near the rad cap). The voltage regulator mounts low in the area of the steering stem. And the fan controller mounts on the upper/left corner of the fan shroud. It's all a tight fit. Yes, the rocker switch is for the dual-mapping of the CDI. This may help: Edited November 5, 2020 by d2w Quote Link to comment Share on other sites More sharing options...
Vertematidog Posted November 5, 2020 Author Report Share Posted November 5, 2020 That's brilliant thanks for the reply. Quote Link to comment Share on other sites More sharing options...
d2w Posted November 5, 2020 Report Share Posted November 5, 2020 No worries. I can send some photos is you need more info. And note that it's possible that the actual wiring may be different than what's depicted in the schematic; in my bikes the rad thermostat is positioned between the fan controller and the fan. Hmmm ... this is actually less than optimal as the fan controller will always be powered. It might be better to ensure that the actual wiring is as the schematic shows. Quote Link to comment Share on other sites More sharing options...
Vertematidog Posted November 5, 2020 Author Report Share Posted November 5, 2020 Photos would be good thank you. Whenever you have a moment. Quote Link to comment Share on other sites More sharing options...
d2w Posted November 8, 2020 Report Share Posted November 8, 2020 OK, here are some photos. The first shows the ignition module (left) and coil (right), The second shows the voltage regulator (top, in the crescent cutout). And the third shows the fan control module (with the 'E') mounted to the fan shroud. Quote Link to comment Share on other sites More sharing options...
Vertematidog Posted November 8, 2020 Author Report Share Posted November 8, 2020 Thank you that helps a lot. It's certainly a tight fit in there. Quote Link to comment Share on other sites More sharing options...
