TwinsDad Posted November 8, 2020 Report Share Posted November 8, 2020 The e-start TRS bikes have not been out too long so difficult finding information on them. I've had mine now about 3 weeks and so far I love it. I'm wondering if anyone has figured out a way to install a trickle charger. Also, bought a pair of Jitsie levers which were supposed to fit but the stock bolt is too large for the Jitsie lever hole. Anyone else have this issue? Quote Link to comment Share on other sites More sharing options...
micm Posted November 9, 2020 Report Share Posted November 9, 2020 Do you need to trickle charge it. Are you having issues with the battery. I only ask because I have just bought one and so far the battery seems fine over a few hours stop start etc. Quote Link to comment Share on other sites More sharing options...
TwinsDad Posted November 9, 2020 Author Report Share Posted November 9, 2020 No problems at all. Just thinking ahead. I have 3 other dirt bikes which have batteries and I keep them on a trickle charger because here in Colorado sometimes it's months between starts. Quote Link to comment Share on other sites More sharing options...
al_orange Posted November 10, 2020 Report Share Posted November 10, 2020 I'm guessing it's a lithium battery? If so, there's no need for a trickle charger. They will hold charge for months at a time no problems. Better to give them a full charge before storage than to trickle charge them. 1 Quote Link to comment Share on other sites More sharing options...
guy53 Posted November 10, 2020 Report Share Posted November 10, 2020 Humm not sure about that Guy Quote Link to comment Share on other sites More sharing options...
baldilocks Posted November 10, 2020 Report Share Posted November 10, 2020 Does the battery get recharged when the motor is running ? Quote Link to comment Share on other sites More sharing options...
micm Posted November 10, 2020 Report Share Posted November 10, 2020 Yes, the engine recharges the battery. No external charging equipment is supplied from new. If for some reason the battery goes flat then you kick start it and run it to charge 1 Quote Link to comment Share on other sites More sharing options...
TwinsDad Posted November 11, 2020 Author Report Share Posted November 11, 2020 Thanks! I appreciate it. Quote Link to comment Share on other sites More sharing options...
al_orange Posted November 11, 2020 Report Share Posted November 11, 2020 If it's got a kick start and a lithium, I would recommend kicking it for the first start of the day as that will warm the battery up and also reduce wear/load on the starter mechanism for that start, which will be the one that take most umph. 2 Quote Link to comment Share on other sites More sharing options...
Jeff B Posted December 3, 2020 Report Share Posted December 3, 2020 If it has a lithium ion battery, make sure you understand the type of charger needed. Don't confuse ion and iron. My KTM has a lithium ion battery and I have a charger made for the ion battery. I don't understand why it requires a special charger, but I was advised to not use a standard charger. BTW...I am thinking about the TRS e start. Currently on a Gas Gas. I'm getting lazy with kick starting. I would like to hear a report after you get more seat time. Jeff Quote Link to comment Share on other sites More sharing options...
ChrisCH Posted December 3, 2020 Report Share Posted December 3, 2020 On 12/3/2020 at 2:56 AM, Jeff B said: ... My KTM has a lithium ion battery and I have a charger made for the ion battery. I don't understand why it requires a special charger, but I was advised to not use a standard charger. ... Expand The lithium battery technology is very different to lead acid. A lead acid battery has all sorts of bad habits and needs care and attention that they tend not to get in light automotive use. A good lead acid battery charger has the facilities to do something called conditioning which the experts tell me my battery needs. Generally the charge is varied during the process as best I understand it. This certainly is the case with our fork lift. Lithium batteries are just replenished. Trickle charging is so the battery doesn't get hot and bend the (lead) plates. Motorbike batteries are much smaller than car batteries and so require a more gentle charge, hence trickle chargers for bikes. I can only guess that the bike's charging circuit is OK with lithium (unless it was the OE). They do seem to be "the thing" for bikes in the last few years. Very sensible for a dirt bike where it might spend the odd minute upside down or on it's side, a bit overkill for a road bike. Quote Link to comment Share on other sites More sharing options...
TwinsDad Posted December 3, 2020 Author Report Share Posted December 3, 2020 Hi Jeff B, I was told that if I ride the TRS often that the battery will stay charged so that's my plan since I no one seems to use a trickle charger on them. As for the bike itself I'm liking it very much. My previous 4 or 5 trials bikes have been Gas Gas and this bike feels pretty close to them as far as geometry, balance, etc. I like everything about it, brakes, suspension, power, etc. I originally was ordering the Raga model but they were coming in later so I test rode a standard R One and it was fine. The Raga has a touch more power but I figure if I ever want to add more punch there is a high compression insert which brings the compression to that of the Raga. The rear shock on the Raga is supposedly an upgrade too but the stock shock is working fine for me. I love the button! I'm 68 years old and I used to get tired of kicking the GG so this one is really nice. Since it's new it starts first kick as well so I try to kick it a fair amount as well but the button is great when you are off-camber or in some other awkward position. 1 Quote Link to comment Share on other sites More sharing options...
Jeff B Posted December 4, 2020 Report Share Posted December 4, 2020 Well this sucks. Now this is another bike I need. I am 61. I'm not very good, but I have fun. Not kicking would be more fun. Jeff 3 Quote Link to comment Share on other sites More sharing options...
ChrisCH Posted December 5, 2020 Report Share Posted December 5, 2020 Since we are back to posting links... https://www.thedailymash.co.uk/news/media/how-to-convince-yourself-social-media-is-more-trustworthy-than-real-news-20201203203145 Quote Link to comment Share on other sites More sharing options...
jacques blackburn Posted November 18, 2021 Report Share Posted November 18, 2021 I bought the TRS Raga with electric start but the bike is so easy to start that I only use the electric start when I am in a difficult place to start. (much easyer than my Ossa Factory 2012). It start first kick hot or cold. If Ossa had this it would have been a sale succes with the advantages of electronic injection and easy start. 1 Quote Link to comment Share on other sites More sharing options...
