GaryHyde Posted November 16, 2020 Report Share Posted November 16, 2020 Good afternoon.... maybe the wrong place.....BUT... does anyone have a fuel system diagram or can point me to the web for the same.... TLR250-R 1986 Japanese model with the secondary fuel tank under the seat... I have fully cleaned, new filters, vacuum pump is priming but I’m not sure which route the fuel would go as I’ve now got an air lock and zero fuel in the float bowl... I have replaced the fuel pipes as they came off so perhaps the previous keeper has tried before help appreciated Gary Quote Link to comment Share on other sites More sharing options...
japes1275 Posted November 21, 2020 Report Share Posted November 21, 2020 This is a good place for Honda part numbers and diagrams which might be of some use if you haven’t found it already: https://www.bike-parts-honda.com/honda-motorcycle/250-MOTO/TRIAL I can’t find your exact model but you might be able find something similar. It’s not the easiest site to navigate so good luck! John Quote Link to comment Share on other sites More sharing options...
bsw Posted November 25, 2020 Report Share Posted November 25, 2020 I have one in the garage, how can I help Quote Link to comment Share on other sites More sharing options...
GaryHyde Posted November 25, 2020 Author Report Share Posted November 25, 2020 Good morning, thanks for your reply, I have now sorted out the pipe work and the motor is running.... thank you again On a further note, I am looking at fitting the lights back on the bike, it currently only has a kill switch, I have the lights front and rear and a loom so hopefully just a matter of laying the loom on the frame and seeing where it lays and the plugs should marry up.... Do you have a manual of any kind for it? Quote Link to comment Share on other sites More sharing options...
bsw Posted November 25, 2020 Report Share Posted November 25, 2020 Sorry no manual just the bike Quote Link to comment Share on other sites More sharing options...
GaryHyde Posted November 25, 2020 Author Report Share Posted November 25, 2020 Excellent..... someone has taken the stripes off mine... stay well Quote Link to comment Share on other sites More sharing options...
section swept Posted November 25, 2020 Report Share Posted November 25, 2020 Your frame appears to be different in that the area next to the steering head looks to be opened out as does the frame near the footrests...optical effect of photo or painted in black...does look like it has the stampings removed. Quote Link to comment Share on other sites More sharing options...
GaryHyde Posted November 25, 2020 Author Report Share Posted November 25, 2020 Ah no..... the previous keeper has put black vinyl inserts into the frame recesses so it looks opened out.... ? may be a way to shave off some weight..? But loose frame strength Quote Link to comment Share on other sites More sharing options...
