Sourcing parts for 2008 GasGas TXT Pro 280
runner10
Hi, New to trials and have just bought a 2008 GASGAS TXT PRO.  Looking for a rear mudguard but can only see 2011 model onwards in online shops, and not having much luck finding air filters, etc.  Is there a general issue getting parts for my model?
Cheers
You don’t tell us where you are ?
There are loads of reputable specialists in the uk for the regular service items ( like filters, pads, levers, sprockets etc), which advertise their wares on eBay if you can’t be bothered googling who’s nearby. They all post stuff pretty quickly, but compare prices because they can vary considerably. There are also lots of aftermarket manufacturers supplying all sorts of other parts, again search out trials dealers. I think the mudguard will be gas gas dealer only, but probably old stock now if you can find one. I had a 05 pro, and new guards were hard to come by 10 years ago, but there are also specialist trials breakers where you might find secondhand. I think the guards will fit 02 to 08 pro, and then the chassis & frame changed for 09/10 or thereabouts so things were different. Lots of other stuff is interchangeable though across various years & capacities, but check before buying.
You can trawl the internet for all the above, but most of the dealers use ebay so it’s like a directory even if you don’t want to buy through it.
Good luck.
Gas Gas now make a blank rear guard and a generic sticker kit that covers 2002 - 2010 bikes. As some of the individual year stickers are getting obsolete they designed a set that covers this complete period. They are good sets.
This is the part number for the complete kit: BT95000CT-BGI-1
Rear guard sticker only: BT95003CT-BGI-1
And the blank rear guard: BT280220007
Search these part numbers and you will find what you need.
Quote from website:
Gas Gas no longer sell individual sticker, or sticker sets specifically for older bikes pre 2010, but they have designed a generic sticker "set" that work on this range of bikes roughly designed around the mid 2000's graphics.
You can purchase the following "RED" sets:
BT95002CT-BGI-1: PERIPHERAL RED STICKERS KIT TXT PRO 2002-2010
Contains the following - Forks, Front Mudguard, Headlight, Frame Logo, Frame boot protectors, swingarm (2)
BT95001CT-BGI-1: CENTRAL RED STICKERS KIT TXT PRO 2002-2010
Contains the following - Tank, Frame infills, Airbox top, seat, side "boomerangs".
BT95003CT-BGI-1:  REAR FENDER RED STICKER TXT PRO 2002-2010
Contains the following - Rear Fender
BT95000CT-BGI-1:  STICKER KIT RED TXT PRO 2002-2010
Full sticker set, contains the 3 above kits combined into one full set.
The Full sticker set is also available in a more predominantly "White" set that suits the 2010 bikes
BT95000CT-BKX-1 STICKER KIT WHITE TXT PRO 2002-2010
  • Thanks 1
