TRS stand
Jimmy80
Managed to snap my stand in my 2017 RR yesterday, I’ve never been happy with the stand and had the bike fall off it many times, before I buy another does anyone know if the newer model stand has been changed ( for the better) and will it fit , or if any other brands will fit
 The newest TRS sidestand is greatly improved (larger and stronger) over yours. I would guess it will fit your 2017 but check with your dealer. Get both the stand and mounting bracket.
  • 3 months later...
Hi, just signed up to the forum yesterday. TRS 280. I was not happy with the "lean angle" of the bike, or the stand. I just fixed mine with a piece of 1/8" stainless steel, drilled, countersunk and bent in the vise with a hammer. Tapped the stand for #10 x 24 flathead screw. It was leaning at 17 degrees from vertical, now it's at 6.5 deg. And it seems less likely to break the stand.
