matgriff Posted December 10, 2020 Report Share Posted December 10, 2020 Hi, does anyone know the type of plastic used for Sherco fuel tanks circa 2004 ? I’m assuming it’s HDPE , high density polythene ? I have a little sherco 50, and i’m going to plastic weld the fuel tank around the petcock area as it’s damaged and had previously been fixed with Epoxy . Thanks Quote Link to comment Share on other sites More sharing options...
mcman56 Posted December 10, 2020 Report Share Posted December 10, 2020 I had a 2002 with a translucent tank and the tank grew over time. I ended up having to slot the mounting hole and it got harder and harder to push down between the tubes. I read somewhere that it is the alcohol in US gas that causes the expansion. I don't think HDPE does that. Does it? Quote Link to comment Share on other sites More sharing options...
matgriff Posted December 10, 2020 Author Report Share Posted December 10, 2020 Hi don’t know , maybe the ethanol in US fuel ? this tank is also a translucent type material , it’s damaged slightly around the petcock area, I’ve removed the fixing part , just need to weld up the small splits , but it’s important to get the right filler rod material , Thanks Quote Link to comment Share on other sites More sharing options...
pauls320 Posted December 11, 2020 Report Share Posted December 11, 2020 Pretty sure the transparent fuel tanks are nylon. Quote Link to comment Share on other sites More sharing options...
mcman56 Posted December 11, 2020 Report Share Posted December 11, 2020 I think I heard nylon also but have no source to back it up, maybe this. https://www.ducatimonster.org/threads/m1100evo-nylon-fuel-tank-coating.338538/ Quote Link to comment Share on other sites More sharing options...
tony27 Posted December 14, 2020 Report Share Posted December 14, 2020 Definitely not HDPE, too flexible. Fairly certain it's nylon Quote Link to comment Share on other sites More sharing options...
matgriff Posted December 15, 2020 Author Report Share Posted December 15, 2020 Thanks for the info, I've ordered some nylon filler rods for the plastic welder, i'll give it a go :-) Quote Link to comment Share on other sites More sharing options...
