dog Posted January 5, 2021 Report Share Posted January 5, 2021 On 12/28/2020 at 10:52 AM, Carl85 said: Hi pal I’ve also sent you a pm for an email of the manual could you please send me a copy mate ?? On 12/16/2020 at 9:09 PM, Primodious said: Sorry my Inbox was full! You should be able to PM me now. Its full again bro !!! Can i get a copy please ? dogeater@gmail.com Quote Link to comment Share on other sites More sharing options...
NAD1 Posted January 5, 2021 Report Share Posted January 5, 2021 On 12/15/2020 at 7:41 PM, todea20 said: My other question is..what do i need to do before starting the bike? Had to be delivered to me due to covid restrictions so just want to make sure i'm doing the right stuff before starting the bike? Pray ? Quote Link to comment Share on other sites More sharing options...
Creepytheclutchmaster Posted January 5, 2021 Report Share Posted January 5, 2021 On 12/15/2020 at 9:52 PM, compactpete said: Too much oil will result in a lean fuel/air mixture. I've pulled the top end off a very hard used Vertigo (not for failure reasons) and can tell you 30ml is more than enough to keep it running spot on. How does useing to much oil cause a lean mixture?, does the fuel injection system recalibrate itself to keep within certain parameters, iv never owned a fuel injection bike so dont know much about the system cheers. Quote Link to comment Share on other sites More sharing options...
tshock250 Posted January 5, 2021 Report Share Posted January 5, 2021 You are substituting fuel for oil if your using too much, hence the lean condition, it’s the same for carb fed bikes. Quote Link to comment Share on other sites More sharing options...
todea20 Posted January 6, 2021 Author Report Share Posted January 6, 2021 On 1/5/2021 at 3:21 PM, nickday1 said: Pray ? ? Thanks God it;s spot on! I really love the fuel injected compared with carbs...much more easy to play with the throttle and very responsive! Quote Link to comment Share on other sites More sharing options...
