harryowens2 Posted January 5, 2021 Report Share Posted January 5, 2021 Hi guys , I've recently had to take my clutch apart on my Gas Gas TXT 250 2000. Does anyone know the torque setting for the springs? cheers in advance Quote Link to comment Share on other sites More sharing options...
zippy Posted January 6, 2021 Report Share Posted January 6, 2021 If that model has the standard 6 springs with the small bolt through the center of the spring, If I remember correctly the torque setting is actually quite low. but I don't remember an exact number. I did find for a Sherco, that the torque for the clutch spring screws is 0.7Nm (0.516 FT/LB or 6.2 IN/LB) http://shercousa.com/pdfs/Workshop_Manual.pdf Page 4 of 60. in the PDF I know it is a different brand, but the clutch design may be similar enough that the torque is similar as well. Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 6, 2021 Report Share Posted January 6, 2021 That is a good way to break a basket that might be hard to replace. Being spring loaded they only need to be snugged up and just barely a small bit more. 1 Quote Link to comment Share on other sites More sharing options...
zippy Posted January 6, 2021 Report Share Posted January 6, 2021 38 minutes ago, lineaway said: That is a good way to break a basket that might be hard to replace. Being spring loaded they only need to be snugged up and just barely a small bit more. 6 IN/LB is just snugged up and just barely a small bit more. Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 6, 2021 Report Share Posted January 6, 2021 When I wrote that Zippy, your post was not showing. Quote Link to comment Share on other sites More sharing options...
zippy Posted January 7, 2021 Report Share Posted January 7, 2021 10 hours ago, lineaway said: When I wrote that Zippy, your post was not showing. It's all good, responses passing in the night........ Quote Link to comment Share on other sites More sharing options...
