GG68 Posted January 6, 2021 Report Share Posted January 6, 2021 I just bought a trial bike a Bultaco Sherpa 350 but I don't know what type of Bultaco it is? The tank is strange and if I compare with other tank from the opening is not in the center of the tank. I have the paper and the bike build is 1975. ON the last picture (yellow), what is this part? Thank you Quote Link to comment Share on other sites More sharing options...
collyolly Posted January 6, 2021 Report Share Posted January 6, 2021 The highlighted part looks like a brake light switch. 1 Quote Link to comment Share on other sites More sharing options...
woody Posted January 6, 2021 Report Share Posted January 6, 2021 It looks like a model M125 with a few alterations. The engine and frame numbers will confirm the model 1 Quote Link to comment Share on other sites More sharing options...
GG68 Posted January 11, 2021 Author Report Share Posted January 11, 2021 Hello, I found the frame number and it begin with 125.XXX so woody you are right it is M125. Do you know where I can find technical date to be sure to restore the bike like original? thank you Quote Link to comment Share on other sites More sharing options...
woody Posted January 11, 2021 Report Share Posted January 11, 2021 I'm not sure technical information will help much as it is more appearance that is a bigger issue if you want to return it to original. Although you have a paper with build 1975 the M125 is a 1974 model which carried over into 75, so if you look for an owners manual it is for the 1974 bike, not 1975 as the 1975 model had small differences If you google images for 1974 Bultaco Sherpa you will find an image of the original sales brochure which will help you see the original appearance From a quick look these are the changes I can see:- Brake light switch has been moved, should be on swingarm above chain tensioner Petrol tank sidepanels and seat base have been cut off (tank and seat are a one piece unit) Tank filler cap top missing Rear mudguard brackets have been moved Seat has wrong cover Shock absorber bottom mounting has been moved A plate has been welded in the frame V above the footrest Wrong carburettor and hose, should be 627 Amal MK1 Wrong front mudguard brackets Chain tensioner should have a pad not roller Mudguards are aluminium originally On the plus side, the main frame structure hasn't been altered, the engine doesn't look battered, wheels and forks are correct, exhaust is correct Quote Link to comment Share on other sites More sharing options...
GG68 Posted January 12, 2021 Author Report Share Posted January 12, 2021 Thanks a lot for the information! I will try to modify the differences to match with the original. Can I take the picture below as reference? Quote Link to comment Share on other sites More sharing options...
woody Posted January 12, 2021 Report Share Posted January 12, 2021 Yes you can The picture is a 1974 bike but it is the previous model that was produced into 1974, not your bike which was the new model introduced later in 1974. However the differences are very small and for the purpose of appearance yes you can use the picture as from this side it is the same as your bike. The only difference on the other side would be the rear silencer 2 Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted January 14, 2021 Report Share Posted January 14, 2021 On 1/12/2021 at 7:47 AM, GG68 said: Thanks a lot for the information! I will try to modify the differences to match with the original. Can I take the picture below as reference? Expand In my opinion the best looking Bultaco ever made 1 Quote Link to comment Share on other sites More sharing options...
