Another Tube/Tubeless Question
JonM
31 minutes ago, 2stroke4stroke said:
I had a Michelin front on a new bike and chased round the rim as you have done. Michelin replaced it, I would suggest you have a faulty tyre.
I'm actually hoping it is that.
At least it would explain what the problem is.
For anybody who's interested, here's the update:
Fitted a Michelin X-Light and at 50lbs it hadn't seated (although went on noticeably easier).
I whipped it off and ran a Dremel with sanding attachment around the inner rim, and then went around it with 80grit emery paper.
I just wanted to remove any tiny burrs or highspots I hadn't noticed.
Tyre back on, pumped upto 60lbs and POP- on she went.
I used a quality pressure gauge and that showed 58lbs, so we now have a seated tyre which went on at circa 58-60lbs.
Whew.
  • Like 3
