motomanandy Posted February 1, 2021 Report Share Posted February 1, 2021 I’ve searched the web and cannot find a supplier for the above, not even China are cashing in on this! Has anyone found a supplier? ? Quote Link to comment Share on other sites More sharing options...
motomanandy Posted February 2, 2021 Author Report Share Posted February 2, 2021 17 hours ago, motomanandy said: I’ve searched the web and cannot find a supplier for the above, not even China are cashing in on this! Has anyone found a supplier? ? This isn’t looking promising ?? Quote Link to comment Share on other sites More sharing options...
arnoux Posted February 2, 2021 Report Share Posted February 2, 2021 If you search by Part numbers you will find a supplier. Try BIT050620007 this is for a 2006 model or BIT05052007 this is for a 2005 model (just the seventh digit changes to reflect the year it was current for, so try 4, 7 etc etc - whatever year you specifically need to make the stickers match. Also some early years were blue plastics, then they went to red) They are the same plastics just different stickers and will fit all BOY50 from 2002 onwards. 1 Quote Link to comment Share on other sites More sharing options...
motomanandy Posted February 2, 2021 Author Report Share Posted February 2, 2021 1 hour ago, arnoux said: If you search by Part numbers you will find a supplier. Try BIT050620007 this is for a 2006 model or BIT05052007 this is for a 2005 model (just the seventh digit changes to reflect the year it was current for, so try 4, 7 etc etc - whatever year you specifically need to make the stickers match. Also some early years were blue plastics, then they went to red) They are the same plastics just different stickers and will fit all BOY50 from 2002 onwards. Thanks but these part numbers don’t find anything on the web. Ill try a dealer tomorrow Quote Link to comment Share on other sites More sharing options...
