Cota 247C
hoodie2
Hi
I'm restoring a 1980 Cota 247C that came to me with the crankshaft broken at the counterweight keyway on the left hand side. Common enough problem. I managed to get a replacement LH half from Cyclesavant in the states. Before I get the assembly rebuilt with a new conrod kit I'd like to replace the ignition side half also, as the keyway and taper both have damage. So I'm looking for a decent ignition side half for a late model with the 20mm pin size. Part number is 2160.00803. Anybody got anything or know of a source either for a crank half or a crank assembly with a good usable ignition side? Any help much appreciated.
Hoodie.
