Tiger cub carb being fouled by crossbar
Robboshome
You do not say witch carb you are using I use an AMAL concentric on both cubs Both engines are move to the left One uses the cub manifold Yes the cable clears the frame but only just The other has a made up manifold that makes the carb more upright and is much longer and has more of an offset
