Oset 20.0 power shortage?
RLSK
Hi all,
Just replaced throttle on late 2013 model because previous throttle kept sticking. Now wondering if we are getting full power that should be available. When my lad tried in the past to pull a wheelie he had to pull on the handle bars like you would on a push bike as well as using full throttle, probably what caused throttle to be faulty. With the new throttle there is no improvement in the ability to pull front end up, this is with speed switch 100%, power dial on full and throttle response dial on full. My lad weighs approx 54kg. We have had the bike a few years and he has used it occasionally often commenting that it wasn't right and now thinking I should have looked into it sooner.
So hoping someone may point out the most likely cause unless this is normal of course.
Many thanks
Rob
When I had a 2015 20r one of the power dials went intermittent, it was the power one. Your bike should wheely easy up full power. I'm 13 stone and my modified oset 20r picked up the front end no probs. The elecs were the only bit that wasn't modified,check under the dials see if the wires are corroding my middle dial was rusty even thow it was covered by dialectric grease.
