Tillerman6 Posted March 7, 2021 Report Share Posted March 7, 2021 Guys- I have most of the torque settings in a shop manual for a B model, but I don't have the torque setting for the 4 aluminum cylinder hold down female bolts. Anybody? these are soft aluminum with a hex shaped top (4 each) if that helps- Thanks in advance! Quote Link to comment Share on other sites More sharing options...
majesty Posted March 7, 2021 Report Share Posted March 7, 2021 1 hour ago, Tillerman6 said: Guys- I have most of the torque settings in a shop manual for a B model, but I don't have the torque setting for the 4 aluminum cylinder hold down female bolts. Anybody? these are soft aluminum with a hex shaped top (4 each) if that helps- Thanks in advance! Hi Mr T, PM me your e mail address again, and I can send you the torque settings chart for the TY250A. Quote Link to comment Share on other sites More sharing options...
majesty Posted March 7, 2021 Report Share Posted March 7, 2021 Sent via Wetransfer. Good luck 😀 Quote Link to comment Share on other sites More sharing options...
Tillerman6 Posted March 7, 2021 Author Report Share Posted March 7, 2021 2 hours ago, Tillerman6 said: Guys- I have most of the torque settings in a shop manual for a B model, but I don't have the torque setting for the 4 aluminum cylinder hold down female bolts. Anybody? these are soft aluminum with a hex shaped top (4 each) if that helps- Thanks in advance! OK- with the help of Magesty- The torque setting for the 4 aluminum hold down bolts in the cylinder are listed as 4.2 to 4.5 m-kg this comes out to 30-32ft pounds of tonque on those aluminum tube nuts!! That seems like a lot to me- Soound right to you ? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted March 8, 2021 Report Share Posted March 8, 2021 12 hours ago, Tillerman6 said: OK- with the help of Magesty- The torque setting for the 4 aluminum hold down bolts in the cylinder are listed as 4.2 to 4.5 m-kg this comes out to 30-32ft pounds of tonque on those aluminum tube nuts!! That seems like a lot to me- Soound right to you ? I figure that some people don't do them up tight enough because on a TY250D I bought, it developed a base gasket leak that stopped leaking when I re-tightened those nuts Quote Link to comment Share on other sites More sharing options...
