Tillerman6 Posted March 10, 2021 Report Share Posted March 10, 2021 (edited) Can somebody with an original TY 250 A tell me what the stock length of the dipstick is? I'm getting 133 mm for just the metal rod below the plastic handle???? The part number on CMSNL is 3221536300, but on there it looks like a plastic one. - I want to make sure I have the right quantity of gearbox oil in there. Thanks for your help! Edited March 11, 2021 by Tillerman6 correction of my mistakes Quote Link to comment Share on other sites More sharing options...
guy53 Posted March 10, 2021 Report Share Posted March 10, 2021 When dry,I put a liter, Guy 1 Quote Link to comment Share on other sites More sharing options...
Tillerman6 Posted March 11, 2021 Author Report Share Posted March 11, 2021 47 minutes ago, guy53 said: When dry,I put a liter, Guy Guy - I did that and the dipstick shows a huge overfill condition. Clutch drags bad. That's cold of course, still sorting this out. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted March 11, 2021 Report Share Posted March 11, 2021 I'll post up a photo of an A model dipstick here tonight Quote Link to comment Share on other sites More sharing options...
feetupfun Posted March 11, 2021 Report Share Posted March 11, 2021 Photos for Tillerman6 Quote Link to comment Share on other sites More sharing options...
guy53 Posted March 11, 2021 Report Share Posted March 11, 2021 do you check the level with the dipstick '' screwed in '' ? Guy Quote Link to comment Share on other sites More sharing options...
Tillerman6 Posted March 11, 2021 Author Report Share Posted March 11, 2021 7 hours ago, feetupfun said: Photos for Tillerman6 feetup fun- that's great stuff- I have the same one and the same measurement 133 mm. Next question- how can anyone get a full 1 liter of oil to stay below the upper fill mark on this dip stick? I can only get .4 liters in and even that much will touch or exceed the upper fill mark when the engine is cold. I can't believe that warming the engine would make another .6 liters get absorbed?? Quote Link to comment Share on other sites More sharing options...
Tillerman6 Posted March 11, 2021 Author Report Share Posted March 11, 2021 feetup fun- that's great stuff- I have the same one and the same measurement 133 mm. Next question- how can anyone get a full 1 liter of oil to stay below the upper fill mark on this dip stick? I can only get .4 liters in and even that much will touch or exceed the upper fill mark when the engine is cold. I can't believe that warming the engine would make another .6 liters get absorbed?? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted March 12, 2021 Report Share Posted March 12, 2021 12 hours ago, Tillerman6 said: feetup fun- that's great stuff- I have the same one and the same measurement 133 mm. Next question- how can anyone get a full 1 liter of oil to stay below the upper fill mark on this dip stick? I can only get .4 liters in and even that much will touch or exceed the upper fill mark when the engine is cold. I can't believe that warming the engine would make another .6 liters get absorbed?? There are a few possibilities for what you are seeing: 1 Not all the old oil was drained out. 2 The bike was not level when the dip was taken. 3 Not enough time was allowed for the oil to flow out of the primary casing and into the gearbox before the dip was taken. 4 There is a problem with the oil flow path between the clutch casing and the gearbox (maybe gasket covering the passage). Quote Link to comment Share on other sites More sharing options...
Tillerman6 Posted March 12, 2021 Author Report Share Posted March 12, 2021 37 minutes ago, feetupfun said: There are a few possibilities for what you are seeing: 1 Not all the old oil was drained out. 2 The bike was not level when the dip was taken. 3 Not enough time was allowed for the oil to flow out of the primary casing and into the gearbox before the dip was taken. 4 There is a problem with the oil flow path between the clutch casing and the gearbox (maybe gasket covering the passage). Those are possibilities I hadn't thought of especially #4- all the gaskets were replaced when the crank was overhauled. #3- I could try filling it again and see how long (or if) it ever does absorb a full liter down to the top mark on the dip stick. I had been testing the amount of clutch drag for maybe 20 minutes before I checked the dip stick and found it to be over filled by about 2". I will start over tomorrow and fill it again with 1 liter- it should level out in say 10 minutes or less- never noticed this problem before. If it fails to level in 10 minutes I will pull off the clutch cover and see if I can see any reason why the oil would get trapped in the clutch area. #2 the kick stand is on the left side away from the dip stick so the oil would drain away from the dip stick and show less than it really has- so that is probably not the culprit. #1- Anything can happen by accident - I did over fill it once because new oil is so transparent on the dipstick, but when I started using ATF, it's red, so there is no mistaking the level that it makes visible on the dip stick. Quote Link to comment Share on other sites More sharing options...
Tillerman6 Posted March 12, 2021 Author Report Share Posted March 12, 2021 Feetupfun and Guy, Starting from a drained crank case- this morning I put in exactly 1 Liter of ATF as a test. As of 3:30 this afternoon, the dipstick is still showing about an inch of over fill. I tried leaning the bike over to the left side about 30 degrees for 30 minutes , and this seemed to drop the overfill condition so that it came down from about a 1.5" overfill to about a 1" overfill, but never did settle more than that.- Tommorow I will pull off the clutch cover and see if I can figure out why the oil is not being distributed enough to use up the 1 liter quantity. It would help if someone else did the same test- drain and fill 1 liter and see what the dipstick shows for a quantity???? 1 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted March 13, 2021 Report Share Posted March 13, 2021 7 hours ago, Tillerman6 said: Feetupfun and Guy, Starting from a drained crank case- this morning I put in exactly 1 Liter of ATF as a test. As of 3:30 this afternoon, the dipstick is still showing about an inch of over fill. I tried leaning the bike over to the left side about 30 degrees for 30 minutes , and this seemed to drop the overfill condition so that it came down from about a 1.5" overfill to about a 1" overfill, but never did settle more than that.- Tommorow I will pull off the clutch cover and see if I can figure out why the oil is not being distributed enough to use up the 1 liter quantity. It would help if someone else did the same test- drain and fill 1 liter and see what the dipstick shows for a quantity???? Here is where 1000 ml comes up to on my A model. I put masking tape on the dipstick so the oil would be visible in the photo. The oil level is 12mm from the end of the dipstick. I dipped it without screwing it in. Quote Link to comment Share on other sites More sharing options...
guy53 Posted March 13, 2021 Report Share Posted March 13, 2021 1) How do you drain the transmission? 2) I can check the level seconds after I refill. Guy Quote Link to comment Share on other sites More sharing options...
Tillerman6 Posted March 13, 2021 Author Report Share Posted March 13, 2021 1 hour ago, guy53 said: 1) How do you drain the transmission? 2) I can check the level seconds after I refill. Guy There is a drain plug underneath the engine case uses a 13mm wrench to loosen- it will be near the centerline and have a gasket under the rim of it. Quote Link to comment Share on other sites More sharing options...
Tillerman6 Posted March 13, 2021 Author Report Share Posted March 13, 2021 6 hours ago, feetupfun said: Here is where 1000 ml comes up to on my A model. I put masking tape on the dipstick so the oil would be visible in the photo. The oil level is 12mm from the end of the dipstick. I dipped it without screwing it in. Feetup fun- I will check the level again this morning, but if it is still high I will be pulling off the clutch cover and have a look- Just going off of faint memories- I think I used to be able to take on a liter with no issues before the engine overhaul. I checked the top case vent to see if it was clogged - not clogged. What do you suppose it is? Quote Link to comment Share on other sites More sharing options...
