2001 sherco 290 cutting out
Ft76
Hi all looking for advice , every time I’m out and it’s wet or I go through streams etc my bike wants to cut out , the only thing that stops it is turn the chime on for a couple of seconds and it’s clear .
my wee fella comes out with me on his sherco and goes through the same stuff his bike is fine
thoughts anyone ??
Start it in a dark garage & see if there is a spark escaping from a crack in the plug cap etc, once it's the easiest path due to dampness you lose all spark
Other possibility is blocked vent tube which is 1 piece with a notch cut out at the bottom, try removing the tube from 1 vent & see if a known situation still gives the problem
