User57927272 Posted March 15, 2021 Report Share Posted March 15, 2021 Are the regina chains on vertigo prone to rust?? Quote Link to comment Share on other sites More sharing options...
stpauls Posted March 16, 2021 Report Share Posted March 16, 2021 Only if you don't oil it every time you wash it. Quote Link to comment Share on other sites More sharing options...
faussy Posted March 16, 2021 Report Share Posted March 16, 2021 Most trials bike come with regina as OE and if not maintained i wouldn't say they rust less or more than any other respectable brand of chain Quote Link to comment Share on other sites More sharing options...
pjw123 Posted March 16, 2021 Report Share Posted March 16, 2021 Regina fine, as long as you look after it. Same for majority of chains. Rust is purely a sign of neglect. Do this : Buy a cheap deep fat fryer (c/w with basket), & a gallon of chainsaw oil. (Non fling, inexpensive, stays on chain really well ). Put a few inches in fryer. Remove chain after every trial, especially in winter. : Remove horseshoe clip & put it straight back on end of the chain in the correct orientation before you remove the chain. That way, you know the chain can go back on in the same direction as it came off. Remove crud with Wire brush, then clean in "parts cleaner" !!! with a stiff brush. If you must use unleaded, then be mindful of Benzene carcinogen hazard & wear correct gloves, etc. Fire up your newly acquired chain maintenance unit (fryer) on a lowish setting & place chain in basket. Allow chain to soak / impregnate rollers in hot oil for a few minutes. Turn out on to some old newspaper. Allow to cool, wipe it off, & refit. As with all the best workshops, worth having a fire extinguisher in the vicinity & small children out of the way. I know its a bit OCD, but it has to be done. 1 Quote Link to comment Share on other sites More sharing options...
