Sherco 290 leaking coolant from somewhere.
Alfreedoe
Leaking lots of coolant from somewhere when engine gets hot. Not from rad cap but somewhere near fan . It pours out until you stop engine. Fan working ok. Could it be radiator leak when it gets hot or something a lot more serious.  Can't find where its coming from .
Hoses seem ok . Don't think it's an expansion tank just the rad.  I was out on it for about 20 mins before it happened. This is second time. First time thought the thermostat was problem cos when I took tank off it was out of its housing. May have dislodged it removing tank. Cable tie holding it in place now. New rad cap fitted. It lasted a lot longer this time, thought it was cured. Could it be as simple as pump not working and rad getting too hot and overpressured , finding a weak spot somewhere? Just can't see where is leaks from. Runs fine no leaks gets hot and seams to pour out.
  On 3/18/2021 at 5:51 AM, wobblenorbed said:
Overspill from over filling the radiator maybe?
Expand
Don't think so  it only happens when hot , theres a lot of coolant spewing out from somwhere  it stops when engine is killed. it's not coming out of the rad cap either . I m thinking it might be rad leak behind the fan, that opens up when hot
Expand
Best pull it and have a look then!  Even if it's not that you may find the cause ...
Expand
If you overfill the radiator the fluid cap expand when hot and “overspill” past the rad cap and down the overspill tube.
Found a split in a hose just above the clip on the cylinder head. Trouble is I can't seem to find a replacement. Splat don't have a 2002 sherco hose just up to 2000 and then from 2006. Does anyone know if either of these will do. I suppose I could cut one to length
  • 2 weeks later...
I had a similar type leak... turned out to be the radiator, the fan plastic housing had rubbed through the water channels at the bottom of the radiator, causing some small pinholes.
I have just repaired it with some JB weld chemical metal, and will put it back together soon... hopefully it should be OK
Mat
