Ty stalling
bsw
Hello
My 74ty 250 starts fine and will run for 10 minutes or so ok then when the throttle is opened it stalls like getting no fuel.
Carb out and cleaned several times.
Today it seemed to recover for a few moments when I pressed the choke.
Vent pipe is not blocked
New points and condensers,  new crank seal on that one side only, must do clutch side next.
Whats left ,carb rubbers or gaskets, reeds
Had anyone this issue before.
I had a similar problem with my ride-on mower, it would run for some time Ok, but then went all weak at the knees.   It turned out to be a blocked fuel tank exit hole, which needed three blasts with an air compressor to clean the debris out of the pipe.
You might have the same problem, best of luck..
Check the tank breather.  Connect pipe to the fuel tap and drain into a container.  If insufficient flow of air into the tank , flow of fuel will slow or stop.
Just had this issue with me Beta.  I had fitted one of those one way valves to the breather pipe and it was faulty.
